It is currently Mon Sep 24, 2018 8:28 pm
PostPosted: Mon May 15, 2017 9:34 am
Has thanked: 338 times
Been thanked: 1768 times
With the recent coverage of Microsoft vulnerabilities to 'exploits' I did a little looking into it.
The list of exploits (serious ones, not the low-risk ones, of which there appear to be hundreds) can be found here:
http://www.securiteam.com/products/W/Windows_XP.html
...showing that XP is not really the system you want to be using at 'any' time if you are serious about your security. OK, if you've applied all the relevant updates then you should be 'safe' - but that doesn't mean future exploits can't be discovered and used against you.
Many people are of the opinion that operating systems such as Linux are far more secure and modern versions (distro's) are both stable and compatible with many hardware platforms. But many potential users are put off by the learning curve and differences from the systems that they are used to hence have either tried and given-up or simply not bothered to try at all.
I found a distro of Linux that is Xubuntu based, can be downloaded for 32- and 64-bit systems, can dual-boot with XP (possibly other versions of Windows too - I haven't looked into it) and that is both graphically familiar, operationally familiar and low on system resource requirements which means it will show an increase in effective speed on your machine if yours is particularly low on performance.
It's called ChaletOS and is found here:
https://sourceforge.net/projects/chalet ... p_redirect
It boots/loads from a DVD or Memory Stick and won't damage anything.
It's worth a shot - for anyone that has a low-spec machine that they want to use, anyone that is considering dumping Micro$oft (for various reasons) or those who have any issues over security.
Call me paranoid (but am I paranoid enough?) but the more we hear of virus attacks and the way .gov approaches your own supposed-private use of OS's I'd rather place my trust in open-source OS's than the corporate stuff that seems to invite (by design?) .gov 'inspection'. Don't even mention 'the Cloud'!!!! :lol:
:thumbleft:
For this message the author kellys_eye has received gratitude : multiman
PostPosted: Tue May 16, 2017 5:05 am
Has thanked: 99 times
Been thanked: 298 times
Because I use Linux Mint also has the XFCE desktop, I have asked around for an opinion on Chalet OS and I gather it is:-
A "small" OS based in Serbia, concern being about the quality of support i.e. security and application updates.
It has the feel of a one man operation, or at best a very very small team.
I have used Mint for some years on my PC and other Family members have installed on their ex XP ones when the hard drive packed up, we find it mostly trouble free and easy, especially the updates.
PostPosted: Tue May 16, 2017 4:33 pm
Been thanked: 1 times
The problem with any Linux distro is the Microsoft apps. We run two servers, and as much as I'd love to get rid of the Microsoft one and just move our software on to the Linux (CentOS) machine, it's never going to happen without complete software rewrites. It's great for ground up development, and I can see a basic Linux PC being "ok" for a replacement to a Windows PC for general web browsing, word processing etc, but it's a learning curve. The best bet (if the machine has the juice) would be to upgrade to a decent version of Windows.
The other thing with XP, it's still fine on machines that don't come in to contact with the internet - many EPOS terminals are still running XP, and the fact they're on closed networks should make them perfectly ok to use for an eternity without upgrading. I suspect part of the problem with the NHS was the number of machines running embedded versions of XP that simply cannot be upgraded as it'd break their core purpose - the thing to do with these machines is get them as far away from the cloud as possible.
For this message the author NotAHobbit has received gratitude : multiman
PostPosted: Fri May 19, 2017 10:31 pm
Has thanked: 3 times
Been thanked: 11 times
Ubuntu and Linux Mint,I have used a live cd like Linux puppy that worked ok on a machine with a broken hard drive for a few months.
PostPosted: Sat May 20, 2017 10:39 am
I understand the problems with Windows compatibility and often decry it for some programs that I commonly use otherwise but moving to a Linux base meant I discovered other alternatives to MS packages (for the most part) that do the job just as well but, more importantly, for FREE!
My suggestion was aimed at those that might suffer problems from the recent virus issue but are either incapable of upgrading to a newer version of Windows of who would prefer not to be 'tied' to an OS that is clearly 'full of holes'! Equally I understand the concerns for those considering a move to Linux but are unfamiliar with both the installation method and the desktop environment hence the suggested version - ease of install, it's not 'permanent' (if you feel you don't like the new Linux version) and a desktop you'd recognise.
Of course Windows is only as vulnerable as 'you' care to make it (fail to apply upgrades, trawl disreputable sites etc) but I can say with some surety that Linux packages don't leave me 'wondering' or - in some cases - 'hoping' I won't fall for infection!
If I wanted to use a PC primarily for internet access and some 'office' type purposes then a Linux distro is a definite improvement in both safety and performance - and let's not forget that it's FREE, as are most (all?) of its application software packages.
For this message the author kellys_eye has received thanks - 2: multiman, sajeel
PostPosted: Thu Jun 22, 2017 6:41 pm
Has thanked: 64 times
Been thanked: 541 times
Driving a Reliant three wheeler I was in a car which insurance records showed was very unlikely to be stolen or involved in a fatal accident, this was because no one wanted a Reliant three wheeler, and those who drove them knew they were vulnerable so drove very carefully. The car did not have better security or more protection for the occupants, in fact the reverse.
So running Linux, you don't get attacked as much, simply as it is unlikely you have anything on the computer worth attacking for, and lack of good quality software means you can't do much with them, as XP gets older and older there will be fewer and fewer people trying to break in, when did you last hear of a virus attack on a Windows 3.11 PC? Same with Amiga no new virus or new software written for them.
I did run Linux for a short time, into Photography I used Gimp, which also runs on windows, however it is an 8 bit program, where CS5 is a 32 bit or even 64 bit program, and also ask some one how to define edge in gimp, and you get a blank expression with CS5 some one has done it before and will show you how.
I am not sure how Linux has progressed? but if it does improve then it too will get hit by the virus, likely more, the more open the more likely to get virus, keeping source codes under lock and key as to Mac will likely mean less virus attacks, but that also means less software, and no cracked software, you would have to pay for every little program.
PostPosted: Thu Jun 22, 2017 11:04 pm
Has thanked: 147 times
Been thanked: 213 times
Gimp is OK, but I find it very cumbersome and long winded to use.
PostPosted: Sat Jun 24, 2017 11:27 pm
Has thanked: 24 times
Been thanked: 402 times
ericmark wrote:
So running Linux, you don't get attacked as much, simply as it is unlikely you have anything on the computer worth attacking.
And yet, a big percentage of the internet's servers are running Linux. Only takes one very clever scrote to F up the internet completely. :wink:
PostPosted: Thu Aug 10, 2017 5:32 am
thanks
PostPosted: Thu Aug 10, 2017 9:43 am
There are viruses and there are exploits.
Anyone can suffer a virus by means of email, dodgy software or implants but Windows seems to have been (deliberately?) designed to allow exploitation of routines and subroutines that enable access to a PC through corruption of the OS.
I've never heard or been victim of a Linux 'exploit' - not even sure if that's possible. Linux isn't developed by individuals with 'sole' access to the code - it's open source so the code is both accessible and checkable by 'anyone' - but not 'hackable' as it has to pass strict review procedures before being allowed to pass as an upgrade or whatever.
I'm quite surer any operating system could be made 100% secure - except certain people don't want it to be....
PostPosted: Tue Oct 03, 2017 12:45 pm
You can use PlayonLinux or Wine to run Windows apps in a Linux environment.
I've been using Ubuntu & Linux Mint lately some excellent gfx apps available like Inkscape.
PostPosted: Fri Oct 06, 2017 3:53 pm
The biggest problem with the NHS computer system is the vast amount of access points, allowing unscrupulous individuals a way in in the first place. :wink: :wink: :wink:
PostPosted: Fri Oct 06, 2017 4:35 pm
Has thanked: 52 times
Been thanked: 548 times
2-3 IT bods to service 4-5000 machines across 3 sites, and a no technical support for the users thats the way the nhs works
OS/2 warp anyone remember that
PostPosted: Fri Oct 06, 2017 7:52 pm
I think the NHS has more computers than that Flash. :wink: :wink: I suspect they also have slightly more than 3 sites. :lol: :lol: :lol: :lol:
PostPosted: Fri Oct 06, 2017 8:09 pm
I was taking about just 1 small trust :roll: :lol: as an example
Many moons ago I applied for a nhs IT job and got through to the second round of interviews so had the tour, but a better job in a school come up that was local to me, less hours, less commuting and about the same money
