It is currently Thu Apr 19, 2018 12:38 pm
Visit Thermo worx
PostPosted: Fri Jul 03, 2009 10:39 am
Alpha cb28 won't fire up for DHW, flowswitch is fine, diaphragm is fine, cleaned out DHW heat exchanger ( not much came out ) also cleaned out diverter valve ( caked up badly ). Put it all back together, fires up for 10-20 secs turns off. Is it the diverter spring not strong enough anymore against the diaphragm spring? If so, should i buy a refurb kit for diverter or a new diverter alltogether. :cb
 Post subject:
PostPosted: Fri Jul 03, 2009 10:58 am
Has thanked: 4 times
Been thanked: 37 times
Check your thermistor, run the tap continually to see if the boiler fires goes out but then relights after a short period of time
 Post subject:
PostPosted: Fri Jul 03, 2009 8:48 pm
Has thanked: 785 times
Been thanked: 847 times
If you remove the horse shoe flow switch, does it keep firing for longer on HW or still go off as your post?
What about the ch?
If above are ok, then I would agree, change the primary ntc.
Dave
www.drlgas.co.uk
 Post subject:
PostPosted: Sat Jul 04, 2009 12:12 pm
Thanks guys, dhw sensor looks like an exploded gigar, waiting for replacement to arrive. ps heating is working ok.
