Page 1 of 1
[ 14 posts ] |
python
Posted: Sun Feb 21, 2010 7:56 pm |
| General Builder |
Joined: Sat May 16, 2009 7:25 pm Posts: 1602 Location: south west UK Has thanked: 0 times Been thanked: 5 times
Would that run a cement mixer?
| Top |
register or
log in
dave.m
Posted: Sun Feb 21, 2010 8:00 pm |
| Senior Member |
Joined: Tue Jun 09, 2009 5:30 pm Posts: 5069 Location: A Yorky in Lancashire Has thanked: 16 times Been thanked: 338 times
What size motor on the mixer?
It says constant output of 650 Watts.
Just looked on the web and there seems to be quite a few that have 370 Watt motors so it would do quite confortably.
dave
_________________ You can always tell a Yorkshireman,
But you cannot tell him much.
| Top |
register or
log in
python
Posted: Sun Feb 21, 2010 8:04 pm |
| General Builder |
I suppose the next question, then, is how do you know what wattage something draws if you no longer have the manual?
| Top |
register or
log in
Hitch
Posted: Sun Feb 21, 2010 8:12 pm |
| Senior Member |
Joined: Mon Jan 16, 2006 8:16 pm Posts: 4669 Location: Somerset Has thanked: 6 times Been thanked: 108 times
Most machines have a data plate/sticker...
Probably a fairly small motor on a mixer, under 1hp, all the power would come from the gearbox.
_________________ Why isn't the number 11 pronounced onety one?
| Top |
register or
log in
register or
log in
python
Posted: Sun Feb 21, 2010 8:38 pm |
| General Builder |
Hitch wrote: http://www.belle-group.co.uk/about/brochureLibrary/English/Mixers.pdf
Is it a belle?
Yours iss 110v isnt it, that little genny wouldnt power the transformer...
yes and yes, so it doesn't matter what I run from the tranny, the tranny itself is too big for it? Shame.
| Top |
register or
log in
Hitch
Posted: Sun Feb 21, 2010 8:50 pm |
| Senior Member |
| Top |
register or
log in
Sparky James
Posted: Sun Feb 21, 2010 8:59 pm |
| Senior Member |
Joined: Wed Dec 31, 2008 9:23 am Posts: 1150 Location: Down on the Farm Has thanked: 10 times Been thanked: 75 times
Watts are constant its the current that changes with voltage. The genny would be ok with a tranny so if your mixer is under say 500w it should be ok.
| Top |
register or
log in
python
Posted: Sun Feb 21, 2010 9:19 pm |
| General Builder |
Thanks. I'll have a look tomorrow.
| Top |
register or
log in
Sparky James
Posted: Sun Feb 21, 2010 9:23 pm |
| Senior Member |
The only possible problem would be starting the mixer with a full drum.
| Top |
register or
log in
Hitch
Posted: Sun Feb 21, 2010 9:26 pm |
| Senior Member |
What about the starting current for the transformer, the genny would trip out surely....? Whats the breaker likely to be on that 5a?
My box sometimes trips a 30a breaker on initial switch on.
| Top |
register or
log in
Sparky James
Posted: Mon Feb 22, 2010 3:13 am |
| Senior Member |
Hitch wrote: What about the starting current for the transformer, the genny would trip out surely....? Whats the breaker likely to be on that 5a? My box sometimes trips a 30a breaker on initial switch on.
The transformer inrush will be limited due the lack of current available from the impedance of the generator windings or inverter. It is possible the genny is a inverter type btw allowing the engine to run slower under light/no load situations.
I used to have a van with a 500w inverter in it and that used to have 2.2kva tranny plugged into it for light stuff like jigsaws and 2D lead lights.
That genny could not blow a 5A fuse in a month of sundays.
| Top |
register or
log in
mikew1972
Posted: Mon Feb 22, 2010 12:43 pm |
| Senior Member |
Joined: Sun Jan 27, 2008 5:54 pm Posts: 1051 Location: North West Has thanked: 0 times Been thanked: 69 times
A 500w electric drill nearly stalls the engine on a genny like that on start up but is OK once running.
I bought a job lot of factory returns of that make but a slightly different model. Most had failed due to a design fault that caused a regulating component to blow even when the genny was not overloaded. It was an easy fix if you knew which component to change and where to get the replacement from. I didn't so I sold them on as still faulty at a profit.
If you want my opinion go for one of the 1500w four stroke ones. Twice the cost but a reasonable bit of kit. Those 850w ones are rubbish.
_________________ Mike
| Top |
register or
log in
Page 1 of 1
[ 14 posts ] |
