Hello peeps, here I am again for plumbing advice.
Friday night and I get a phone call at work, a pipe has gone from having a pin prick leak (been like that for months lol) to a full scale waterfall and its up under the back of the kitchen sink. Mum's first thought was to shut the valves off in the airing cupboard (reported that one kept on spinning but eventually shut) and then she pulled the hatch in the floor and turned the valve off that is on the house side of the pump, then turned the pump off too.
Long story short but that burst pipe is now fixed. I opened all the valves back up and put the pump on, expecting water to gush out into the cold tank in the loft - but it didn't. Just a trickle, and more water came out when the pump switched off than when it was on - but still only talking a trickle rather than a 'flow'.
I assumed it had an air lock, but the pump pressure gauge was reading 2bar when off, and when it was pumping, it got up to 3bar then switched off (which is perfectly as it should be for this pump in this system) and the pump itself was fully primed and didn't need further priming. I closed the valve under the floor just on the house side of the pump, disconnected the pipe and checked the flow of water when the pump was running and it was a good strong gush ((last time we had an airlock I was able to put my hand over this pipe as water only came out in dribs n drabs, and when released, that cured the blockage)) so connected it all back up, but no change to the flow in the cold tank in the loft.
Throughout the day, the pump has been coming on for maybe about 20-30 seconds and then going off (not all that often), and to our surprise, the tank in the loft did fill up quite quickly, but the force of water being pumped to the tank is not right. Plus, now that the tank is less than half full, the pump won't come on at all. Even turning the kitchen cold tap on, which comes directly from the pump doesn't get the pump running for any length of time. Something that I haven't tried yet, is going right back to the well and filling the pipes with water to make sure no air lock between the pump and footvalve.
Just to confuse the issue, we also found out that there is no water coming out of any of the hot taps. I drained a little from the hot water cylinder and plenty came out, so we connected the kitchen cold tap to kitchen hot and opened both up. All the other hot taps had water coming out of them, and it sounded like water was also running into the hot water cylinder. After a few mins, this stopped, so I assumed it would be pushed up to the cold tank in the loft via the hot tank overflow, but it wasn't coming out of there either.
So to sum up, theres no water in any of the hot taps, and the pump seems to think that the cold tank in the loft is full when its not! Anyone help? Just going to stick some pics on photobucket so I can illustrate my story
