| Author |
Message |
dave_01
Posted: Wed Dec 07, 2011 9:23 pm |
| Newly registered Member |
Joined: Thu Nov 17, 2011 5:54 pm Posts: 33 Has thanked: 1 times Been thanked: 0 times
Hi I keep getting air in an open vented heating system
The header tank has water in it about 100mm or so about the 15mm feed pipe. There is not a large amount of air a few seconds from 2 or 3 rads
I have run the pump on the lowest setting but still get air in there.
The layout is feed up from boiler then elbow in to a pipe with vent then cold feed then onto the pump the vent and feed are about 1" apart and then about 6-8 " to the pump then from the pump about 8" to the three way valve
Any idea's?
Dave
| Top |
thescruff
Posted: Wed Dec 07, 2011 9:33 pm |
| OAP |
Joined: Mon Mar 10, 2008 12:46 am Posts: 39960 Has thanked: 187 times Been thanked: 2110 times
A pic would help.
Hold a glass of water under the vent pipe, does it suck the water out if you turn the pump on and off a few times.
Does the air smell very strong, a bit like rotten eggs.
_________________ If you feel you have benefited from the Free advice given on the Forum, Please consider making a donation to UHM's Nominated charity, read all about it and donate here : donnas-dream-house-charity-t52110.html
| Top |
register or
log in
dave_01
Posted: Thu Dec 08, 2011 8:28 am |
Hi No smell to the air coming out I will try the glass under the vent pipe
Dave
| Top |
register or
log in
dave_01
Posted: Thu Dec 08, 2011 8:44 am |
Hi This may help  Dave
| Top |
register or
log in
dave_01
Posted: Thu Dec 08, 2011 9:26 am |
Hi Right just done the glass under the vent pipe and the level in the glass dropped about 1-1/2" after starting the pump three times So its pulling air down the vent? Whats the best way to stop this?
Dave
| Top |
register or
log in
thescruff
Posted: Thu Dec 08, 2011 9:35 am |
| OAP |
Need to see where the vent and feed join in the pic
| Top |
register or
log in
dave_01
Posted: Thu Dec 08, 2011 9:49 am |
Hi The vent is the pipe in the front with the white cable fixed to it The feed is in the pipe going to the pump
Dave
| Top |
register or
log in
thescruff
Posted: Thu Dec 08, 2011 9:57 am |
| OAP |
The cold feed from the tank. ?
| Top |
register or
log in
dave_01
Posted: Thu Dec 08, 2011 10:04 am |
Hi Tank cold feed is back from the vent towards the pump in the middle of the pic Will try to get a better photo up
Dave
| Top |
register or
log in
dave_01
Posted: Thu Dec 08, 2011 10:12 am |
Hi 1 is the cold feed 2 vent pipe 3 feed to pump  Dave
| Top |
register or
log in
thescruff
Posted: Thu Dec 08, 2011 10:15 am |
| OAP |
Run a magnet around those pipes and see whether it's sticks or any resistance.
| Top |
register or
log in
dave_01
Posted: Thu Dec 08, 2011 10:24 am |
Hi No a magnet dosen't stick and no resistance
Dave
| Top |
register or
log in
thescruff
Posted: Thu Dec 08, 2011 11:07 am |
| OAP |
Em, something is not quite right. How high is the header tank and vent pipe, perhaps a pic showing them.
| Top |
register or
log in
dave_01
Posted: Thu Dec 08, 2011 11:15 am |
Hi The header tank is approx 6ft above the height of the hot water tank The vent pipe is about 6-8" over the top of the tank
There is quite a bit of muck in the header tank could the 15mm pipe be restricted? Would changing it to a 22mm feed help?
Dave
| Top |
register or
log in
thescruff
Posted: Thu Dec 08, 2011 11:22 am |
| OAP |
The signs say the cold feed is partially blocked, which is why you tried the magnet.
Would be worth cut a section out where it joins the system.
| Top |
register or
log in
