It is currently Mon May 21, 2012 11:13 am
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Dec 24, 2011 5:56 pm
Has thanked: 1 times
Hi
Bleed the rads again and a very small amount of air in two of them
Just one more thing i now have a humming from the pipe work could this be a sign the pump is on the way out?
The noise changes if you slow the pump down or speed it up?
Dave
PostPosted: Mon Jan 02, 2012 1:32 pm
Just bleed rads again and still getting air in two of them.
Strange not sure what else it could be
Dave
PostPosted: Sun Jan 15, 2012 7:34 pm
Hi
If i run the pump of the lower speed i dont get much heat in the house and less air in the rad
Turn the pump up and better heat but more air in the rads
Could this be a micro leak pulling air in ?
The change to combined vent and feed has not made much of a change to the air in the rad with the pump set on 2
Any idea's?
Would a leak sealer help?
Dave
PostPosted: Thu Jan 19, 2012 11:12 pm
Hi
Could this be a fault auto air vent letting in are when CH is on?
Dave
PostPosted: Sun Jan 29, 2012 10:45 pm
Hi
Bleed again and still air in there :dunno:
System has had a a leaking rad valve replaced and leak sealer added
What next?
Dave
PostPosted: Wed Feb 15, 2012 7:00 pm
Has thanked: 8 times
Been thanked: 2 times
Hi Dave
Did you get your air in the system resolved as the posts have stopped
:salute: :salute: :salute:
PostPosted: Wed Feb 15, 2012 10:18 pm
Hi No not yet
I have reduced the amount of air but filling the level in the header tank higher
I need to move the header tank higher
But i just haven't had time to do it yet
Dave
PostPosted: Sat Mar 03, 2012 4:58 pm
Hi Dave
Did you move the header tank higher if so has this sorted your problem, if yes how high have you moved the tank from its original position
PostPosted: Sat Mar 03, 2012 7:03 pm
Has thanked: 24 times
Been thanked: 70 times
Only guessing but I should have thought the vent pipe in the picture and diagram could cause a syphon action, in my system the vent is "h" shape with the top of the vertical open and the leg of the n into the header water; also I'm pretty sure its venting on the hot side; perhaps this is just another method and I am sure The Scruff can pass comment, please.
PostPosted: Thu Mar 15, 2012 4:13 pm
Hi
Header tank now moved 700mm higher
So time will tell when i get to run it for a few days and see what happens
Dave
PostPosted: Sat Mar 17, 2012 10:30 am
Hi
First run with the header tank now in its new home and no air looking good so far :huray:
Will check again in a few days after the heating has been used more
Dave
PostPosted: Wed Mar 28, 2012 8:52 am
Hi Dave
Have you curred all your problems now,,,,, just by moving the tank 700mm higher
cheers mate...........
PostPosted: Wed Mar 28, 2012 9:12 am
Hi
It looks that way
No air in system on the last test
Will know more in time when its run longer but for now its looking like it might be fixed :huray:
Dave
