It is currently Sat Jan 19, 2019 12:36 pm
 Post subject: Air in dhw
PostPosted: Thu May 17, 2018 7:19 am
Been thanked: 4 times
Hi. I have a bungalow (2 bathrooms) with open vented dhw system with a cylinder next to one of the bathrooms. Both showers are fed off pumps.
I have been having trouble with air getting in the hot side of the showers- particularly the one next to the cylinder. I have had a Surrey / Essex valve fitted on top of the cylinder to no avail. Both bathroom showers are fed via this valve.
There is also an orange coloured grunfoss circulation pump to the left of the cylinder and the direction of flow is indicating away from the cylinder. Two different plumbers who are friends have said the pump is the wrong way round. I intend to reverse it but could someone please explain why
A- how air may be getting in.
B- the function of the pump as it seems to makes no difference if it is switched on or off.
Thanks.
 Post subject: Re: Air in dhw
PostPosted: Thu May 17, 2018 8:04 am
Has thanked: 840 times
Been thanked: 938 times
Can't give any answers as to the air problem, but the bronze pump is to keep the hot water circulating without a tap on so when a hot tap is turned on, the water will be hot straightaway.
Is it a large bungalow with the hot taps a long way from the cylinder?
Dave
www.drlgas.co.uk
PostPosted: Thu May 17, 2018 11:18 am
Yes some taps are 20m away.
PostPosted: Thu May 17, 2018 5:30 pm
That is why you have the bronze pump then
Dave
www.drlgas.co.uk
PostPosted: Thu May 17, 2018 5:56 pm
Has thanked: 316 times
Been thanked: 960 times
Are the pumps above the showerhead level?
PostPosted: Thu May 17, 2018 10:45 pm
One shower pump is on the floor by the cylinder. The other bathroom has the pump to the shower in the loft space above. Both feed from the top of the cylinder however, the gold dhw circulation pump is pumping out of the cylinder via a pipe that is half way down the cylinder. Surely it should be pumping into it?
Sometimes when the nearest shower is turned on the shower pump screams as its just got air in it so i have to switch it off and run the hot water to let the air out.
Im stumped as to how air is getting in.
