It is currently Mon Feb 19, 2018 12:01 am
Visit Thermo worx
PostPosted: Sun Sep 10, 2017 5:35 pm
Hello!
I am getting conflicting information so would like someone in the no to point me in the right direction!
I have a Bosch 25kw external oil boiler. The central heating in my house is all 15mm pipe (reduced from 22 about a meter from boiler).
I have built a 2 story extension which i habe roughly calculated will need 7kws worth of rads. Current system is 11kw.
Now.....i understand that the CH should be 22mm flow and return with 15mm coming off to the rads. Whoever installed my system hasnt done that!
Can i use 15mm in extension and connect to existing?
Should i use 22mm in extension? Will this cause flow/balancing issues when connecting to existing?
Do i need to change current set up to 22mm (worst case as ceilings down in current house!).
Or are there any other options?
Thanks.
PostPosted: Sun Sep 10, 2017 9:08 pm
Has thanked: 768 times
Been thanked: 822 times
In a perfect world the existing pipe work would be changed to 22mm.
15mm will carry around 4kw of heat adequately, whilst 22mm is rated around 18Kw.
Dave
www.drlgas.co.uk
PostPosted: Sun Sep 10, 2017 9:18 pm
Dave
Thanks for your reply. When you say about the kw capacity of both 15 and 22mm is that for a certain length? Or in general? The only reason i ask is that the current house system is completely 15mm and my rads total 11kw (calculated using sizes).
Sorry if i have misunderstood
Thanks again.
PostPosted: Sun Sep 10, 2017 10:16 pm
If you had really long pipe runs then I suppose technically you would go up a size, I am not that clever to work these type of things out, but in your average domestic set up the length of the pipe runs wouldn't really come in to it.
Undersized pipes may well still let the rads get hot, but may take a lot longer to do so.
If one is to be technical, then the temperature difference between flow and return back at the boiler would also be a factor in working pipe sizing out as well. e.g. whether it is a condensing boiler (20c) or standard boiler (11c)
Dave
www.drlgas.co.uk
