| Author |
Message |
fordy
Posted: Tue Jan 31, 2012 11:19 pm |
| Senior Member |
Joined: Mon Jan 21, 2008 9:21 pm Posts: 2391 Has thanked: 14 times Been thanked: 149 times
Just wondering if you use oil based as an undercoat and then say a water based stainwood over the top how much will this affect the topcoat, yellowing is my main quandry?
Has anyone done a sample and actually seen the timescales etc?
My oil based choice would be coverstain and then a w/b satin
| Top |
dynamod
Posted: Wed Feb 01, 2012 7:19 am |
| Senior Member |
Joined: Thu Apr 14, 2011 7:06 pm Posts: 1412 Location: Scottish Borders Has thanked: 55 times Been thanked: 183 times
Haven't tried this one yet, but I see where you're coming from. TBH, would have to say sticking to one of the better covering topcoats would hopefully minimise any yellowing shining through. Honest answer though - I've also been wondering if hybrid paints may suffer from any yellowing. Farrow & Ball Estate Eggshell is the one that most readily springs to mind. Given that it's an alkyd/acrylic hybrid will there be any (delayed yellowing) God, this trade has turned complicated these days.
| Top |
register or
log in
Adz76
Posted: Wed Feb 01, 2012 9:08 am |
| Senior Member |
Joined: Tue Mar 29, 2011 7:28 pm Posts: 143 Has thanked: 0 times Been thanked: 33 times
I recently did my porch with 2 Coverstains and then Dulux Trade Weathershield WB Gloss and its fine mate. I'm sure Dulux would advise against it but it was outside and I needed the first 2 coats to go off quick. Not sure whether it will yellow, I'd guess not as the top coat is WB but only time will tell I guess!You might need to give it 2 topcoats but apart from that crack on mate.
| Top |
register or
log in
register or
log in
register or
log in
Morton
Posted: Wed Feb 01, 2012 11:27 am |
| Senior Member |
Joined: Thu Mar 31, 2011 10:59 am Posts: 191 Has thanked: 118 times Been thanked: 11 times
moderator2 wrote: Hi yes, can you add it in please?
| Top |
register or
log in
paintycait
Posted: Wed Feb 01, 2012 12:38 pm |
| Senior Member |
Joined: Mon Nov 21, 2005 11:12 pm Posts: 1383 Location: Scotland Has thanked: 5 times Been thanked: 87 times
we've tested both acrylic and hybrid - 2 types. Acrylic doesn't adhere as well as I would have liked but it does harden over a period of about 14 days. The adhesion is dramatically improved by sanding with a fine sandpaper.....no surprise there. Hybrid adheres brilliantly - no issues at all. The F&B is fine and sticks very well even with minimal or no sanding. The Sikkens BL has its own solvent born primer undercoat which is superb. If not using the sikkens primer u/coat, I would definitely be thorough with sanding as it seems to have less adhesion to un-sanded precats and the like. The F&B is alkyd/acrylic, Sikkens is polyurethane/acrylic which gives you an indication of behaviour
If you put these hybrids in a room with no natural light they would yellow somewhat - but there is less of the resin in these products and also less yellowing of the binder materials so it will be reduced and I have yet to have seen evidence of yellowing myself but I would never offer guarantees if the conditions were likely to induce yellowing
_________________ Skilled Artisans are not cheap....Cheap artisans are not skilled. http://www.decoratescotland.comhttp://decoratescotland.blogspot.com/
| Top |
register or
log in
Have Brush Will Travel
Posted: Wed Feb 01, 2012 5:10 pm |
| Senior Member |
Joined: Fri Mar 23, 2007 5:30 pm Posts: 2979 Location: Wales, isn't it. Has thanked: 1 times Been thanked: 154 times
I have often done oil based unders and then water based (gloss) as a top coat...no problems at all..works great on radietors and the water based still white.
The situation aint really much different to painting over existing oil based finish with water based.
Using oil based undercoat always gives you a longer working time with the gloss and doesnt drag as much.
_________________ I hate being bi-polar...its Brilliant!!!!
| Top |
register or
log in
jozeffo
Posted: Wed Feb 01, 2012 6:05 pm |
| Senior Member |
Joined: Tue Dec 02, 2008 7:52 pm Posts: 2448 Location: South London Has thanked: 58 times Been thanked: 272 times
The yellowing of the non-volatile longer chain Hydrocarbons in the undercoat should not show through the WB satin provided that you have not tried to one coat the satin, thus leaving it Opaque rather than white.
Consider this:- If you had undercoated a stain to seal it, and then emulsioned over it twice, it would have never yellowed through before because the yellowing in emulsion remains below the finish sheen. If the sheen didn't seal the surface, you would be able to wipe the trim with a rag with turps and make it whiter.
You are inventing things to worry about.
| Top |
register or
log in
register or
log in
fordy
Posted: Wed Feb 01, 2012 7:58 pm |
| Senior Member |
Not inventing things to worry about just asking a question!
If the base/u/c coat is yellowing surely it must have some sort of effect on the top coat.
Not a great fan of w/b especially from bare wood.
Sometimes what may seem a stupid question is the most important!
| Top |
register or
log in
Puma
Posted: Wed Feb 01, 2012 8:21 pm |
| Senior Member |
Joined: Fri Mar 05, 2010 8:40 pm Posts: 1606 Location: Bristol Has thanked: 57 times Been thanked: 187 times
Yes it's definitely a good question. Cannot work out Jozeffo's post apart from the fact the point - if you put a solid coat on it will cover even if it yellows. But a couple of coats of wb isn't solid. So from that perspective the question remains unanswered.
Try Mythic wb primer?????
| Top |
register or
log in
B Richardson Decor
Posted: Wed Feb 01, 2012 8:22 pm |
| Senior Member |
Joined: Sat Dec 18, 2010 3:02 pm Posts: 407 Location: S.W. Scotland Has thanked: 21 times Been thanked: 49 times
paintycait wrote: The Sikkens BL has its own solvent born primer undercoat which is superb. Hi PC, the solvent born primer you mentioned is this the water soluble one they recommend ? As it is indeed the daddy, and sets up lovely for the top coats, essential in my opinion to achieve the best poss finish, having tried acrylic u/c and 123 they just don't stand up to the BL primer in terms of obliteration and finish.
_________________ I wanna build my Rome and get high but i can't find my matches...
| Top |
register or
log in
Puma
Posted: Wed Feb 01, 2012 8:30 pm |
| Senior Member |
That's good advice - the BL primer is quite similar to oil based. Go for Mythic if you are looking for opacity.
Both don't have much body and you have to blitz out fine textures with p240
| Top |
register or
log in
B Richardson Decor
Posted: Wed Feb 01, 2012 8:32 pm |
| Senior Member |
Hi Puma , still to try the Mythic range ....  Bertie will have me guts ...
| Top |
register or
log in
