It is currently Thu Jan 24, 2019 4:32 am
PostPosted: Fri Jul 26, 2013 3:30 pm
Has thanked: 5 times
Good afternoon gents
I would like some advice and guidance regarding the size of wall plugs to use for schrieber kitchen wall units of varying size,the screws that I have are 10x2.5inch and 10x3inch,the construction of the wall is breeze block with dot and dab so there is a small cavity behind the plasterboard.
the plugs that i was going for are Fischer UX6L Extra Long Universal Wall Plug,would they be ok,
any advice would be greatly appreciated ,regards Brian
PostPosted: Fri Jul 26, 2013 4:09 pm
Has thanked: 698 times
Been thanked: 2021 times
you need for red plugs 1 1/2" in the plug plus the fitting size and a 6-6.5mm
for brown plugs its 1 3/4" and 7mm masonary drill
all this information is on the plastic holding the plugs together
suspect the screws you need will be nearer to 2"
scrub my comments i missed the fischer bit lol
PostPosted: Fri Jul 26, 2013 4:17 pm
Has thanked: 36 times
Been thanked: 260 times
cut the wall out where the brackets are going to be and fix a strip of plywood in the void and use 3"10s
PostPosted: Fri Jul 26, 2013 8:41 pm
Thanks for the information from both parties
PostPosted: Mon Jul 29, 2013 12:23 am
Been thanked: 2 times
I would recommend hammer in square anchors they are very good in d&b walls.
