It is currently Fri Feb 22, 2019 2:27 pm
PostPosted: Sat Mar 10, 2018 7:44 pm
Has thanked: 3 times
I have a round water but that just overflows from a couple of holes at the top. I'd like to add a proper overflow to the side & route it elsewhere, can't work out how to do this given the surface it's going on to is curved.
PostPosted: Sat Mar 10, 2018 8:38 pm
Has thanked: 56 times
Been thanked: 285 times
something like this perhaps would do it
https://www.amazon.co.uk/Harcostar-Over ... B000A63K60
https://www.amazon.co.uk/25mm-Corrugate ... GKS4FP62EN
PostPosted: Sat Mar 10, 2018 9:14 pm
Has thanked: 40 times
Been thanked: 1429 times
Although the water butt is curved, I don't think it will make that much difference with what you use, so long as it has a flexible washer.
PostPosted: Sat Mar 10, 2018 11:22 pm
Has thanked: 702 times
Been thanked: 2027 times
my thoughts
it may be blow molded or injection molded
it may also be designed with more material/strength at the base to accommodate a hole for the tap
you may find the top will be weaker and could split with a hole drilled i dont know :dunno:
its more a suggestion off what to check before doing anything invasive :lol:
PostPosted: Sun Mar 11, 2018 8:29 am
Has thanked: 16 times
Been thanked: 98 times
I just use one of these with a length of corrugated hose attached,
https://www.diy.com/departments/floplast-overflow-waste-tank-connector-dia-21-5mm-white/178484_BQ.prd
a few wraps of ptfe tape will take up the gap in the curve, it only needs to be hand tight.
Drill it out gently with the right size spade bit or I have used a heated piece of metal tube in the past to melt a hole.
PostPosted: Sun Mar 11, 2018 8:12 pm
Thanks for the replies, unfortunately I carelessly omitted a vital piece of information in that as far as I can tell, it's a sealed unit so I can't get behind to put a the nut on.
PostPosted: Sun Mar 11, 2018 8:58 pm
how does the water get in :scratch:
maybe "T" off the input iff a fixed pipe
PostPosted: Sun Mar 11, 2018 9:20 pm
Has thanked: 107 times
Been thanked: 469 times
You'll need an Essex Flange then. Can be totally installed from the outside. (usually used on hot water cylinders)
Cheers,
Darren
PostPosted: Mon Mar 12, 2018 7:23 am
Perfect, thanks :-)
PostPosted: Mon Mar 12, 2018 7:30 am
The water butts (there's 3 of them connected together) are fed from the garage guttering, the butts each have 2 holes in the top which allows excess water to escape, I could block them up but there are screw in plastic lids which i suspect leak.
At the end of the day, I've inherited these things as I've moved into the house that has them, not sure if I need them really but I might find them useful.
