It is currently Wed Jan 23, 2019 8:10 pm
 Post subject: Accenta 8 Mini Question
PostPosted: Sat Apr 07, 2018 10:50 pm
Hi
I've moved house and now I've got an Accenta 8 Mini alarm.
It seems to work well but I'd like to change/add a couple of zones in program 2.
The documents I've found online don't seem to help me do this.
One says to press Prog, enter your engineer code and all the zones should light up.
That happens and tamper is also lite.
It then says to press Prog again, when I try that I get a beep and nothing else happens.
Anyone know how to do this properly ?
PostPosted: Sat Apr 07, 2018 11:33 pm
Has thanked: 39 times
Been thanked: 1415 times
It sounds like you do not have the engineer code.
You either need to find it, or default it.
PostPosted: Sun Apr 08, 2018 12:28 am
Thanks. I may speak to a local alarm company and get them to sort it out.
I'm not sure how to default it and then reprogram the alarm!
PostPosted: Sun Apr 08, 2018 12:34 am
Its in the (engineers) manual.
..............but some times it is best to leave it to those who are familiar with said product, I would suggest you ask them first if they are familiar with your panel. (Most alarm companies have a favourite panel or two that they install, and anything else they may struggle with)
PostPosted: Sun Apr 08, 2018 8:54 am
Thanks for the advice. We were told it was the same code to do everything.
I'm can do a walk test etc using this code.. I need to reset the user code, I assume I need the engineer code to do this.
Can anyone recommend an engineer in the north west, Fylde coast area ?
PostPosted: Sun Apr 08, 2018 9:32 am
You were told wrong.
An intruder alarm panel has a minimum of two codes. One is the "master code" the other is the "engineers code"
Think about it, if it was just one code, how would you programme it in the first place?
You do not need the engineer code to change the master code, the master code can change the master code (Read the manual) the engineers code can default the master code if it has been lost.
Probably not. The "problem" with forums is there are so few regular posters and the country is so big, its unlikely some one is close enough to be able to physically help.
As I said before, call a couple of alarm companies, be honest with them and say you have a "Accenta 8 Mini alarm" do they know anything about them. (its not hard to download a manual for most panels, but some panels do have their unique "quirks" that only a regular user would know of.)
PostPosted: Sun Apr 08, 2018 10:00 am
Approved Electrician
Has thanked: 168 times
Been thanked: 582 times
https://www.security.honeywell.com/uk/d ... gineer.pdf
I suggest trying 9999 as it is the default engineers code. If it has been altered then it shows you how to do a factory reset.
PostPosted: Tue Dec 11, 2018 1:40 pm
Hi
Very late update to this thread.
I had a few issues with the alarm so called a local engineer, I needed the battery, bell box and a sensor replacing.
All sorted and seems to be working much better.
I have one query though...
When I enter my code, Prog 2, zones 3 & 7 are off by default and that is the way I want them.
there are occasions when I may need to set Prog 2 but have 7 enabled.. I was expecting to do..
Code, Prog 2, Omit, 7, Set
When I try this I get an error beep when I press 7, so it looks like I can't change that zone as it is set off by default for this program.
Is there any way to allow zone 7 to be off by default for prog 2, but allow me to enable it if needed ?
PostPosted: Tue Dec 11, 2018 5:59 pm
As before, you need the correct engineer code, then you can go into programming and change it as required.
PostPosted: Tue Dec 11, 2018 6:05 pm
Hi
I now have the engineering code.
The engineer who set this up didn't think it was possible to allow you to enable / disable the zones if they are set as off by default.
Can this be done, now I have full access to it ?
If so are there any easy to follow steps I can do ?
PostPosted: Tue Dec 11, 2018 6:50 pm
I don't have the manual or engineers code, you do, what does the manual say?
For this message the author someone-else has received gratitude : wine~o
PostPosted: Tue Dec 11, 2018 9:03 pm
Looking at the manual it appears this can't be done..
'Zones programmed as omit prevent will give a reject tone'
I can't see how to see if they are omit zones or not!
PostPosted: Tue Dec 11, 2018 11:43 pm
If you can not "see what they are" then make them spare / not used, then re-programme them as what you do want.
