It is currently Tue Jul 17, 2018 1:14 am
PostPosted: Wed Sep 27, 2017 10:52 am
Has thanked: 1 times
The day mode (green light) is showing. I key in my code, rapid bleeping, zone 1 (front door) lights up red, system PIR monitors change the rapid bleeping to intermediate bleeping as I move, but opening the front door makes no difference, so I cannot set the alarm, even after resetting (pressing reset button twice), it just goes back to 'day mode' (green light). Can you help please?
PostPosted: Wed Sep 27, 2017 6:47 pm
Has thanked: 44 times
Been thanked: 1294 times
It sounds like the alarm thinks the front door is open.
Either the magnet is missing / broken or the contact is broken.
For this message the author someone-else has received gratitude : Johnnyo
PostPosted: Wed Sep 27, 2017 8:02 pm
Many thanks will investigate.
PostPosted: Thu Sep 28, 2017 4:53 pm
Some-one else, can you possibly help. I wanted to leave our house before I tried to remedy the front door issue. I would like to temporarily omit zone 1 which is the front door. The other zones will then be active. I inputted my code, the rapid tone started, I then pressed omit, the rapid tone stopped, all four zone lights lit constantly. I pressed zone 1, the zone 1 red light flashes, when I pressed 'set', the exit bleeps started, (2 bleeps per second). However, when you exit, even after a minute, the system had not set itself.
I then tried a magnet on the front door contact, just the same. I then removed the door contact and joined the two brown wires, again, no joy.
So, two problems, the original, but also how to OMIT zones, so at least the house is partially alarmed?
Regards and thanks, John.
PostPosted: Thu Sep 28, 2017 6:11 pm
Has thanked: 1452 times
Been thanked: 3724 times
From memory of the accord to omit a zone you input user code then button 6 followed by the zone number... then set the alarm as usual.
but you have to do this every time you set the alarm
PostPosted: Thu Sep 28, 2017 6:47 pm
Chances are you can not omit circuit 1 because it is the final door.
Flip it on its head......
You have isolated the front door you come home the device in the hall sees you, your alarm goes off. :cb
Its quite normal not to be able to omit / isolate anything that is used for the setting / unsetting of an alarm
You could of course alter you alarm so it has no front door and the hall pir is your final device.
This assumes you have a device in the hall, you could either re programme it or swap the circuits round (But you would need to link out the door circuit)
There are also lots of on line suppliers that you can get a new door contact from. (But not screwfix)
PostPosted: Fri Oct 13, 2017 11:55 am
Has thanked: 696 times
Been thanked: 28 times
Have you checked resistance on door contacts open and closed ?
