It is currently Wed May 16, 2012 10:39 pm
 Post subject: a felt (torch on ) roof
PostPosted: Fri Dec 23, 2011 10:42 am
I have a large area of torch on felt which is now beginning to show its age.
The last time I spoke with the roofers (who laid it) they said that there was no point in overpainting it with alluminium (?) paint -even though in the earlier sections they had done this.
As they are professionals I followed their advice but now I wonder if they really do need this extra protection and also whether I should repaint the areas where the paint has worn off...?
I notice that the areas around the seams have cracked a bit.
Is there a product that I could put over these (smallish ) areas that might prevent further deterioration (something like liquid rubber perhaps) ?
thanks for any advice
PostPosted: Fri Dec 23, 2011 11:55 am
Has thanked: 132 times
Been thanked: 468 times
felt roofs will last between 10 and 25 years dependent on construction any longer is borrowed time once a roof shows signs off failing its only a year or so before it needs replacing
PostPosted: Fri Dec 23, 2011 1:05 pm
Has thanked: 12 times
Been thanked: 158 times
You can paint some Acropol over the joints and solar reflective paint over whole roof area.
This will buy you a little time, but sounds like its near the end of its life.
If your planning on renewal go for EPDM.
PostPosted: Fri Dec 23, 2011 1:07 pm
thanks
where does the felt go?
Is it the seams or is it all over?
Does a protective covering of alluminium paint give it extra years longevity (assuming it was painted at the time of installation) ?
(sorry cotswold builders we posted simultaneously...)
PostPosted: Fri Dec 23, 2011 1:54 pm
Acropyl goes on the lifting joints, it has glass fibre strands in it for strength.
Solar Reflective paint over entire area, give it a couple of coats.
You would have had extra years life out of it, the solar paint would have protected it from the sun, needs doing every 3/4 years.
What you could do if your roof is still in good sound condition and no leaks, apply a torch on green mineral capsheet, it would last quite a few years and no need for repainting.
Users browsing this forum: mav75pry and 11 guests
