It is currently Wed May 16, 2012 10:38 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 21 posts ]  Go to page 1, 2  Next
PostPosted: Mon Oct 04, 2010 10:10 pm
Has thanked: 2 times
Been thanked: 3 times
Just come across this new offer from Rutlands.
http://www.rutlands.co.uk/cgi-bin/psPromotions.cgi?promo=84
66 piece router set for £130. I'd be using it for home occasional, not professional use. This looks as though it's most router bits I'll ever need. Anybody got a set of these and if so are they any good?
PostPosted: Mon Oct 04, 2010 10:30 pm
Has thanked: 178 times
Been thanked: 19 times
I bought a set of the faithfull brand 1/4 about 30 odd bits, ok for diy,they look a good set 1/2 inch so no good for my 1/4 router.
PostPosted: Tue Oct 05, 2010 6:38 pm
Well, just bought a set, so will have to be on the look out for a 1/2" router now :)
For this message the author jmc67 has received gratitude : diyguys
PostPosted: Tue Oct 05, 2010 6:50 pm
Rutlands and axminster sell some good quality gear,what router do you think you will purchase.
PostPosted: Tue Oct 05, 2010 7:08 pm
No idea yet, haven't thought that far ahead, lol. Will have a look round here and havea chat with a few people before splashing out :-)
PostPosted: Tue Oct 05, 2010 9:22 pm
Has thanked: 132 times
Been thanked: 468 times
if we are honest 3 routers are the ideal number small medium and big beastie
idealy a 800w lightweight for easy handleing a1200 for light 1/2" routing and 1600 plus for table mounting
what you need to remember is a router table isnt ideal in a confined space as you need twice the material length clearence to run it over the table
so a 3m length off timber will need 20ft
and routering large cumbersome objects are far better with a hand held as any deveation will reflect in the condition off the mouldings
look at ryobi as the 1150ert is a half inch even though they dont say so it is 1/2"
http://uk.ryobitools.eu/Catalogue/cutti ... 1150VN.htm
PostPosted: Tue Oct 05, 2010 11:27 pm
Thanks Big-all. Think I'll have to have one for now. I checked the 1150 out, and even though it mentions 12mm collet size on the ryobi website, everywhere that has it for sale says it's for 1/4" and 3/8" router bits only. The 2100 Ryobi makes does take 1/2" though so am a bit confused :scratch: Any negatives to the 2100 when using for handheld as I wont have huge amounts of space to use with a table all the time?
PostPosted: Wed Oct 06, 2010 1:52 am
i have the 1150 as one off about 6 router trimmers and its definatly 1/2 inch lol
the trouble with using a large router for delicate work is the top heavy 5.5kg or so ballanced on a 21 or 42mm edge spinning round at 20.000 rpm :scratch: :scratch: :mrgreen:
PostPosted: Thu Oct 07, 2010 11:27 am
Cool, ok Big-all, will get one ordered :-) sounds like it should be more than adequate for the home DIY use I've got in mind.
PostPosted: Thu Oct 07, 2010 11:35 am
Has thanked: 32 times
Been thanked: 83 times
The Ryobi BA has sugguested jmc67 will last you for years mate and you'll be very happy with it, ive still got 2 old ryobi's from '02 and there still going strong and ive never had any problems with them.
PostPosted: Thu Oct 07, 2010 12:55 pm
just remember because its a low powered 1/2 inch you need to take extra passes on bigger cutters as in the normal rules are half the cutter shank per pass
so a 1/4"at 6.35 would be say 3.2 a 1/2" 12.7mm would be 6.36
so somwhere in the middle will be 4.25
small rebates off perhaps 7x7mm can be cut in a oner because its a relativly small amout off the cutters width cutting unlike say a 3" panel cutter
also check before you buy any larger cutters if theres a minimum recomended power required[dosnt appy to the 66 set :huray: ]
other essentials for routering
non slip mat =toolstation http://www.toolstation.com/shop/Hand+To ... 220/p85326
ptfe cutter lubricant maybe ts deffinatly s/fix probably rutlands http://www.toolstation.com/shop/Automot ... 795/p63929
and diamond slip stones for honning
and alternative bearings that increase/decrease the rebate width or remove the the little step on some cutters
http://www.rutlands.co.uk/power-tools-& ... t---1_2%22
somtimes the smaller/larger bearing within a set off cutters can be swopped giving you 2 sizes but not always
drill a small hole for the allen key between the cutters in your box then you will never loose it
PostPosted: Thu Oct 07, 2010 1:19 pm
Good to know StyxSIS, and thanks again Big-all, I presumed there would be some rules of thumb regarding power to number of passes, and depth of cut etc
PostPosted: Thu Oct 07, 2010 1:37 pm
read the several edits to the last thread
PostPosted: Thu Oct 07, 2010 3:51 pm
The router bits set arrived from Rutlands today - first impresisons, is that it looks good quality especially for the price. However I hadn't realised it's imperial only. My naivity I suppose but I'd assumed it would be metric/imperial and din't even bother checking. Not a huge problem but for cutting rebates for 18mm MDF/ply will need a different bit :oops:
PostPosted: Thu Oct 07, 2010 8:06 pm
whenyou say rebate do you mean a slot or a rebate around the edge??
