It is currently Wed May 16, 2012 10:38 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Thu Oct 07, 2010 11:28 pm
Has thanked: 2 times
Been thanked: 3 times
Sorry, me getting my words mixed up again - happens alot. I meant the slot cut into the uprights for the shelf to sit in. No big deal, just a bit surprised to a see nothing but imperial sizes in the set.
PostPosted: Thu Oct 07, 2010 11:36 pm
OAP
Has thanked: 187 times
Been thanked: 2107 times
You could make a second pass to expand the width of the slot.
PostPosted: Fri Oct 08, 2010 12:22 am
Has thanked: 132 times
Been thanked: 468 times
i just butt glue and screw into 12mm had no probs yet
mark the shelve sides in pairs side by side 2 lines 12mm apart
drill a 3mm hole 25mm from each end between the lines every 2" or so
use 2" no 6s
line the shelve up with the side between the lines as a letter "T" or"L"
lay on the face so the front lines up drill a single hole into the shelve though the hole in the side
place a mastic clamp in the area where the screw will enter the shelve at the top back glue the shelve edge with a 1mm glue beed insert the screw firmly but slowly on the last 2 turns use the pozi 2 bit as a countersink before insertion
holding the 2 componants firmly in place drill a hole near the back pilot with the bit again and insert screw again carefully on the last 2 turns
undo the clamp if the board dosnt delaminate leave the clamp off
coutersink and drill out all holes on that side repeat every shelve down the side
repeat for the other side
when complete rub glue into any cracks and use a mastic clamp to close up the cracks
if you plan on routering a rebate for the back you need to assemble top and sides rebate 6x6mm in the back then affix the shelves that are 6mm shallower to sit from the front to the rebate
if you want to put a small moulding on the face you can do that at the finnish unless the top overhangs then you need to router the top and the the top 4 inches off the shelves as these cant be reached with the top in place
clear as mudd eehh
or as scruff says 2 passes although 12.7 is perfect for 12mm as the mdf will swell and the glue can easily fill 1mm indeed if you cut a 12mm slot you would have to ease the mdf edges to fit in :thumbleft:
PostPosted: Fri Oct 08, 2010 8:43 am
Thanks again guys. Thescruff - such an obvious thing to do, I am now somewhat embarassed I didn't think of it :oops: . Most of it made sense big-all :wink: although I might have to re-read and take notes a few times, lol.
PostPosted: Sat Oct 09, 2010 12:25 am
dont worry if you come down plan a few hours for demonstrations :boxing: :boxing: :huray:
PostPosted: Sat Oct 09, 2010 8:23 pm
Will do Big-all :-)
