It is currently Wed May 16, 2012 10:35 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 13 posts ]
 Post subject: 3 way 90 deg elbow
PostPosted: Mon Nov 21, 2011 7:39 pm
Has thanked: 22 times
Hi
Just a quicky, is there such a thing as an 90 deg elbow but also a T, ie 3 way. If so what's its correct name?
Thanks, Chris.
 Post subject: Re: 3 way 90 deg elbow
PostPosted: Mon Nov 21, 2011 7:56 pm
Has thanked: 162 times
Been thanked: 605 times
It's called a "T" you can buy equal T's..where the pipes are all equal... or reducing T's where they are not..
Here's one I made earlier...
PostPosted: Mon Nov 21, 2011 8:37 pm
Thanks for getting back so quick, I need a tee I know, but I also want it to fit tight into a corner, so it's an 90 deg elbow as well as a tee. I could put an elbow & a tee side by side, but I want a pipe to run around the corner but also one to run up, tight in the corner of the room. Its central heating, a very old house, I'm trying to re route some pipes to avoid a huge unsightly boxing in.
PostPosted: Mon Nov 21, 2011 9:31 pm
Has thanked: 7 times
Been thanked: 17 times
Are you asking for a "T" were all three outlets are at 90 degrees to each other?
Trevor
PostPosted: Mon Nov 21, 2011 9:57 pm
I think so yes, an elbow with another spur coming out of the top, in 15mm.
PostPosted: Mon Nov 21, 2011 10:13 pm
But thats just a "T" used on its side
PostPosted: Mon Nov 21, 2011 10:23 pm
Has thanked: 143 times
Been thanked: 215 times
No i'm guessing couchie want's to run a horizontal pipe on one wall, then carry it on horizontal on another wall, but right in the corner of the room as it turns he also wants to 'T' off and run a pipe up the wall right in the corner????? is that right??
a 3 way elbow??
Professional Kitchen & Bathroom Fitters | Master Painters and Decorators | Brighton & Hove
For this message the author Colour Republic has received gratitude : couchie
PostPosted: Tue Nov 22, 2011 12:40 am
OAP
Has thanked: 187 times
Been thanked: 2107 times
The OP wants a corner tee.
What size and material.
You mention 15mm so if I assume copper, then a Yorkshire YP36 in 15mm or 22mm.
For this message the author thescruff has received thanks - 2: Colour Republic, couchie
PostPosted: Tue Nov 22, 2011 6:45 am
Thanks Scruff, I can honestly say I don't think I've even seen a copper on before, didn't know they did them but then again at that price I'm not surprised I've never seen one :shock:
PostPosted: Tue Nov 22, 2011 8:30 am
Spot on guys, thats just what I'm after. So it's a corner tee, I'll have a look on line this eve to see if I can find a couple, not to worried what material, copper would be nice, but as long as it's ok for heating it'a good.
Thanks all, Chris.
PostPosted: Tue Nov 22, 2011 8:36 am
The picture i've posted is not suitable, I just posted it as an example of the shape of fitting you were after. Where as the fitting scruff mentions is suitable. But the are pricey at over £20 a fitting.
I'm unsure why you need to get it so close to the corner, you can still get it nice and tight with normal fittings. What's more you say it's for the heating so I assume you need to bring 2 pipes up in the corner (flow & Return) if that's the case you would only be abe to bring 1 of the pipes up with that fitting
PostPosted: Tue Nov 22, 2011 8:48 am
OAP
To be fair it isn't a fitting I have ever used, maybe, along the wall, up the wall, and through the wall they could be good.
PostPosted: Tue Nov 22, 2011 1:43 pm
Thanks for the advice. I thought it might be a simple of the shelf fitting, at that price I'll get as close as I can with standard fittings. Your right in what you say, there are two so only one would tuck in tight anyway.
Users browsing this forum: fitzy and 9 guests
