It is currently Tue Oct 16, 2018 8:45 pm
 Post subject: 28mm gas feed necessary?
PostPosted: Tue Nov 07, 2017 2:07 pm
Has thanked: 3 times
Hi all.
I had an RGi visit yesterday evening for the combi upgrade survey. He had a look at the meter and said
the 22mm gas pipe will need to be upgraded to 28mm, something to do with 1mbar differential.
This means a fair amount of work to replace as the existing supply has at least:
Pipe run is:
At least 2 bends
1.5 metres horizontally from gas meter
Then vertically 3 metres (from room above)
and then across the landing around 4metres to the chimney area bbu.
The new combi will be 3 metres away from the chimney area ideally.
The only other gas appliance after the combi upgrade would be a 4 ring hob.
He's the only RGI who mentioned this so far, is it absolutley necessary if I had a Eco Rf36 installed
or can I get away with a smaller Kw combi?
Advice greatly appreciated.
PostPosted: Tue Nov 07, 2017 2:58 pm
Has thanked: 838 times
Been thanked: 927 times
From the dimensions you have posted and assuming there are probably more bends/elbows hidden, I would say yes he is correct, especially if the gas hob comes off the boiler gas supply pipe.
At a guess it will need 28mm up to the tee for the hob, then 22mm from there to the boiler, but without seeing the situation I can't accurately say.
Dave
www.drlgas.co.uk
PostPosted: Tue Nov 07, 2017 6:56 pm
Has thanked: 316 times
Been thanked: 960 times
If you only have one bathroom the ECO 30 will be more than enough. Ignore the published flow rates they are the absolute minimum unlike most manus that hype the maximum :wink:
For this message the author Razor has received gratitude : mani3
PostPosted: Tue Nov 07, 2017 11:47 pm
Mind at ease... Yes it's 1 bathroom 8 rads.
It was a surprise, good thing I asked here!
