It is currently Thu Jul 19, 2018 8:57 am
PostPosted: Sun Jun 18, 2017 9:59 pm
Has thanked: 2 times
Been thanked: 1 times
I have a 2 way switched light already in operation on the staircase and I'm in the process of changing the switches over to more modern looking ones. The issue I have it that both the upstairs and downstairs switch independently control the upstairs light on/off etc but if the downstairs switch is on then the upstairs switch has no effect - it will briefly turn the light off in the process of using the switch but it will remain on almost as if the downstairs switch is some form of master.
I've attached a diagram of the wiring that is there currently but I do not understand how to correct the wiring so that if the light is on then either switch will turn it off and vice versa.
Any advice is much appreciated!
File comment: Existing wiring
PostPosted: Sun Jun 18, 2017 10:26 pm
Has thanked: 44 times
Been thanked: 1295 times
There is no definitive answer since it is down to who ever wired it, chose to wire it. (see my signature)
But, i will have a guess. (and it is only a guess)
Downstairs switch.
Take the black out from com, and put it in L2.
(leave the link wire where it is now)
For this message the author someone-else has received gratitude : hammo
PostPosted: Sun Jun 18, 2017 10:57 pm
Has thanked: 696 times
Been thanked: 28 times
If you can get pics of both switches wiring should be able to work out for you
PostPosted: Sun Jun 18, 2017 11:30 pm
But his drawings show the same as pictures will. (In regards to what goes where)
PostPosted: Sun Jun 18, 2017 11:52 pm
The colours are not correct
PostPosted: Mon Jun 19, 2017 3:06 am
Has thanked: 64 times
Been thanked: 539 times
Image Shown is standard two way wiring, there is a line wire to both switches, and to get two way switching with only two wires, you need to borrow that line wire from another switch, your diagram shows a link where the line is borrowed, however you show it going into com with another wire, it would need to go into L2 on it's own to work.
However using just two wires instead of three can cause interference with hearing aids and can also cause a borrowed neutral, so up and down stairs must be from the same fuse or breaker otherwise, it can't safely be done.
PostPosted: Mon Jun 19, 2017 7:56 am
multiman, how do you come to the following conclusion?
If he only has red and black, then he only has red and black. The colour of a cable makes no difference as to if it will work or not.
PostPosted: Mon Jun 19, 2017 10:40 am
I agree I want to see how the switches are wired, it's very rare not impossible to be done like that usually a 3 core wire is used for second switch
PostPosted: Mon Jun 19, 2017 7:03 pm
Approved Electrician
Has thanked: 163 times
Been thanked: 565 times
Downstairs switch.
That would be my guess.
For this message the author OnlyMe has received gratitude : hammo
PostPosted: Mon Jun 19, 2017 7:44 pm
Thanks all! I'll let you know how it goes
PostPosted: Mon Jun 19, 2017 8:09 pm
Excellent! Downstairs black into L2 leave the link where it is! Worked a treat thanks everyone for your help :cheers:
For this message the author hammo has received gratitude : multiman
