It is currently Wed May 16, 2012 10:33 pm
 Post subject: 2 way lighting circuit
PostPosted: Tue May 19, 2009 1:03 pm
Hi
anyone got a wiring diagram to show how to wire 2 ceiling lights so they both work together from two 2 way switches.
i have 2 ceiling lights in the kitchen each working from it's own switch . i want to change this so both lights can be turned on/off from either of two switches ( one at each of the doors into the kitchen)
thanks scratch
 Post subject:
PostPosted: Tue May 19, 2009 3:00 pm
Has thanked: 2 times
Been thanked: 60 times
Have a look in the A-Z it gives lots of ideas for all sorts of tasks, however, the link below should help.
http://www.ultimatehandyman.co.uk/two_way_lighting.htm
John
PostPosted: Tue May 19, 2009 3:08 pm
Hi John
thanks already looked at that link - but still confused- if i am wiring 2 ceiling lights to be worked from two 2 way switches ( so both lights both on or both off from either switch)- is a switch wire run down from each lamp and then the 2 switches are connected as 2 way switches?
thanks maddie
Users browsing this forum: No registered users and 9 guests
