It is currently Tue Apr 24, 2018 2:10 am
 Post subject: 2 way 2 gang switches
PostPosted: Mon Jan 30, 2012 3:41 pm
I am trying to fit two new '2 way 2 gang' light switches to replace the existing switches that control the downstairs hall light and upstairs landing light.
At present there is a '2 way 2 gang' light switch down stairs and a '2 way 1 gang' light switch upstairs, so at present I can operate the upstairs landing light from both the upstairs and downstairs switches, but can only operate the downstairs hall light from the downstairs switch.
In each switch box there is two sets or red and black wires (the black wires all have red electrical tape round them) and the earth wires.
Please see the picture below, on the left is how the switches are currently wired, and on the right is the two new switches and how the wiring appears now i have disconnected it from the old switches.
File comment: wiring
So, at present in the downstairs '2 way 2 gang' switch there is a red wire that goes into 'Com' with the corresponding black wire going into L2 but on the opposite gang. The other red and black wires go into L1 and L2 respectively, on the same gang as the first red wire. There is then a short red wire connecting both 'Coms'.
Then in the upstairs '2 way 1 gang' switch there is a red wire that goes into 'Com' with the corresponding black wire not attached to anything. The other red and black wires go into L2 and L1 respectively.
As such could someone please advise me if it is possible to change the switches so that they are both '2 way 2 gang' so I can opearte both lights from both the upstairs and downstairs switches. If so, please could you also explain how to configure the wiring.
I hope this makes sense.
Many thanks,
Steve
PostPosted: Mon Jan 30, 2012 4:12 pm
Has thanked: 1405 times
Been thanked: 3632 times
Can't be done with the wiring you've got..
PostPosted: Mon Jan 30, 2012 5:51 pm
Wineo thanks for your reply. What would I require? And would it be a big job?
Cheers
Steve
PostPosted: Mon Jan 30, 2012 5:56 pm
At the very least, 3 core and earth from one switch to the other. (Probably 2 of these)
Depending on how your consumer unit is configured, you may need further alterations.
PostPosted: Mon Jan 30, 2012 6:04 pm
Would this be an easy task for an electrician or would it require making a mess of the walls?
PostPosted: Mon Jan 30, 2012 6:46 pm
almost certainly some chasing out of walls required (Unless your wiring is already in conduit, which is Unlikely)
Main problem would be how the lighting circuit is split between upstairs/downstairs..
