Page 1 of 1
[ 11 posts ] |
| Author |
Message |
vanduara37
Posted: Sun Jan 23, 2011 8:21 pm |
| Newly registered Member |
Joined: Sun Jan 11, 2009 8:05 pm Posts: 86 Has thanked: 17 times Been thanked: 3 times
Helping fit a bathroom suite and the the customer was asking if i could do the tiling,when she showed me the tiles they are about 900mm to a 1000mm long,i have a Rubi ts60 proplus but only cuts tiles up to 650mm long,my question is there a cutter that can cut these tiles manually or do the need cut with electric cutter ? (or should i just say can,t do it and save myself a lot of grief  )
| Top |
Razor
Posted: Sun Jan 23, 2011 8:41 pm |
| Senior Member |
Joined: Wed Nov 14, 2007 10:21 pm Posts: 5127 Location: Northampton Has thanked: 76 times Been thanked: 372 times
I'd usually use a diamond blade in a 4" grinder. Before you agree the job check how flat the walls are with a decent straight edge or you're heading for real trouble
_________________ As always help on here is free, however if you think you have saved a decent sum of money why not click the link to find out about the charity we're currently supporting? A couple of quid makes a real difference. donnas-dream-house-charity-t52110.html
| Top |
register or
log in
Inky Pete
Posted: Sun Jan 23, 2011 8:53 pm |
| Senior Member |
Joined: Fri Feb 03, 2006 2:34 pm Posts: 1199 Location: Cheshire Has thanked: 6 times Been thanked: 84 times
Yeah, any unevenness at all in the walls and at that size they're going to kick out like you wouldn't believe. Best of luck!!
| Top |
register or
log in
vanduara37
Posted: Sun Jan 23, 2011 9:05 pm |
Was thinking just giving it a bodyswerve but hate admitting defeat
| Top |
register or
log in
Rookery
Posted: Sun Jan 23, 2011 9:44 pm |
| Member |
Joined: Wed Apr 28, 2010 8:11 pm Posts: 100 Has thanked: 0 times Been thanked: 19 times
At this length, the tiles are likely to have a bow in them making it even harder to avoid lipping, especially if fixing brickbond. Put 2 tiles face to face and check. Sounds like these are expensive tiles so if you're going to use a grinder, practise first on some cheap tiles.
| Top |
register or
log in
Posted: Sun Jan 23, 2011 9:49 pm |
| Pro Carpenter |
Joined: Sat Dec 16, 2006 10:11 pm Posts: 10461 Location: redhill surrey an auld reekie laddie Has thanked: 132 times Been thanked: 468 times
theres challenges and theres disasters waiting to happen and four tiles across a room mmm not good
_________________ we are all ------------------still learning
| Top |
register or
log in
vanduara37
Posted: Sun Jan 23, 2011 9:58 pm |
The way i see it she has to get someone to do this job, the family put a lot of work my way so should i shirk it or get a doctor to prescribe me a load of Prozac and get on with it.
| Top |
register or
log in
Inky Pete
Posted: Sun Jan 23, 2011 10:10 pm |
| Senior Member |
If you've got doubts about it and aren't sure you'd be able to produce a finish you'd be proud of yourself with these materials, then it probably wouldn't be a good idea to put your reputation with a valued customer on the line.
If you don't have the correct tools to cut such large format tiles accurately, then there's your get out. Show them pictures of some big expensive overhead wet cutters and explain that its a more speciallist job than you are equipped for.
| Top |
register or
log in
Crooksey
Posted: Thu Jan 27, 2011 1:54 pm |
| Senior Member |
Joined: Sun Jan 03, 2010 3:16 pm Posts: 303 Has thanked: 0 times Been thanked: 26 times
Get a coal chisel and some gripfill and man up! Only joking, I would pass this on to someone else, maybe as they are a good customer you could "project manage" the job so they are still effectively dealing with you.
_________________ My project blog - Check it out
| Top |
register or
log in
Beachcomber
Posted: Mon Jan 31, 2011 11:48 pm |
| Senior Member |
Joined: Thu Jul 30, 2009 5:26 pm Posts: 830 Has thanked: 17 times Been thanked: 58 times
Simple really - a customers house is not the place to learn new skills! Knowing your limits saves you hassle and your customers upset and extra cost. It also keeps your rep intact!
_________________ If at first you don't succeed - remove all evidence that you tried.
| Top |
register or
log in
register or
log in
Page 1 of 1
[ 11 posts ] |
