It is currently Sat Jan 19, 2019 11:24 pm
 Post subject: 13 amp socket
PostPosted: Wed Jan 03, 2018 11:26 am
Has thanked: 408 times
Been thanked: 1483 times
I've got a 13 amp switched double socket in my hallway, it's behind a Welsh dresser, one half has my main land-line phone permanently plugged into it and the other has a short diy extension lead leading to a surface mounted double socket which is accessible just to the side of the dresser. The diy extension has a paper shredder permanently plugged into it and the other half gets used for the Hoover when necessary.
A couple of weeks ago the shredder stopped working. I tried it in another socket elsewhere and it was fine. The phone was still on.
I pulled out the dresser, unplugged the extension and tried the shredder direct in the double socket behind the dresser, it didn't work, the phone, plugged into the other half of that double socket was still on. I unplugged the phone, and as I did so the shredder started up, (there was a piece of paper sat in it). Wiggling the phone plug caused the shredder to sometimes work and sometimes not.
I've had to wait for a good time to turn the power off if necessary(is there ever one?) and so this morning I pulled out the dresser again and unscrewed the socket from the wall, (still live) I checked that the connections were tight, the earth took about a half turn to tighten up but that was all, everything else was good. The switch on the socket for the phone turns on and off but the other switch seems to be stuck on.
Everything now appears to be working as it should be, but all I've done is given a half turn to the screw to tighten the earth wire, would a very slightly loose earth wire cause an intermittent problem like that or is it likely to be something else?
 Post subject: Re: 13 amp socket
PostPosted: Wed Jan 03, 2018 11:30 am
Has thanked: 698 times
Been thanked: 2014 times
would say something else as it would have to be wired up very wrong for an earth wire to make any difference :dunno:
For this message the author big-all has received gratitude : ayjay
PostPosted: Wed Jan 03, 2018 11:36 am
Has thanked: 875 times
Been thanked: 378 times
A guy on YouTube named Thomas Nagy (very good) said everytime you reconnect a wire to a socket you should cut the end of the old piece, strip a new piece in and reattach. He said because the wire. He sad the reason is the wire gets crushed and sometimes it works loose causing an intermittent fault. Just an idea.
For this message the author Argyll has received gratitude : ayjay
PostPosted: Wed Jan 03, 2018 6:00 pm
Has thanked: 39 times
Been thanked: 1407 times
Change the whole socket.
PostPosted: Wed Jan 03, 2018 6:06 pm
That's what I thought.
It's been OK (and completely untouched) for several years. Nothing's been reconnected, just two 13 amp plug tops inserted into the existing socket a long time ago.
I have it in mind to do just that: but why?
PostPosted: Wed Jan 03, 2018 6:37 pm
Has thanked: 1509 times
Been thanked: 3834 times
Have you checked the plug on the shredder ??? could just be a dodgy connection there.
PostPosted: Wed Jan 03, 2018 6:40 pm
Because you also said
For this message the author someone-else has received gratitude : ayjay
PostPosted: Wed Jan 03, 2018 10:31 pm
The shredder works fine in any other socket, (and it's still working in the old one at the moment).
I'll get a new socket sometime over the next few days and fit it - leccy off! :-)
I might even get around to changing the shaver socket in the bathroom when the leccy is turned off.
I think I must have had the new one about 6 or 7 years, :oops: but I don't use it, I've got a beard, (and so has the wife now). :mrgreen:
