It is currently Fri Feb 23, 2018 10:14 pm
Visit Thermo worx
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 20 posts ]  Go to page 1, 2  Next
 Post subject: 110v site power supply.
PostPosted: Sun Nov 12, 2017 7:30 am
Has thanked: 1075 times
Been thanked: 799 times
With 110v site power supplies, what’s the easiest/cheapest way to ‘step-up’ to 240v ac?
No replies from H&S Johnnies please, I’ve got a Bronze Swimming Medal & fully conversant.
Time-served Plumber/Heating Engineer & general wind-up merchant.
The Plumbers Anthem
If you have found my help or tips useful please donate here. Thank You;
Gas Safe RGI
Scottish, British & Proud.
I'm not or never claimed to be Chris Williams.
PostPosted: Sun Nov 12, 2017 7:35 am
Approved Electrician
Has thanked: 151 times
Been thanked: 531 times
Plug it into a 460V supply :scratch:
PostPosted: Sun Nov 12, 2017 7:42 am
You can buy step up transformers for about £100 quid or so.
Or swap the 230V plug for a socket and connect up a 110V transformer to the 110V site with a Jesus cord.
PostPosted: Sun Nov 12, 2017 8:10 am
Has thanked: 328 times
Been thanked: 1708 times
:lol:
Borrow some one else's transformer and wire it in reverse.
But to power what? Many items of electronics use SMPS supplies which can take anything from 90V to 250V AC input - check the labels.
PostPosted: Sun Nov 12, 2017 2:49 pm
Has thanked: 64 times
Been thanked: 521 times
You can as said get step up transformers normally blue, as to using a second step down to step up it depends on the transformer, because the whole idea is to isolate trying to use them in reverse can cause over heating and large volt drop.
For small items you can get auto transformers, I would remove them from fluorescent lamps to run radios and the like, the old fluorescent lamps were really 230 volt with an auto transformer to step up, the auto transformer was normally wound off centre tap so 127 - 0 - 110.
Any transformer with duel input so you can select 110 or 230 volt can normally be used as an auto transformer. You simply don't use the secondary.
PostPosted: Sun Nov 12, 2017 7:00 pm
Has thanked: 953 times
Been thanked: 1775 times
I removed the transformer from a fluorescent lamp to run a radio on site but that’s all it would do. It wouldn’t even charge our batteries for the cordless drill.
For this message the author steviejoiner74 has received gratitude : Dickie
PostPosted: Sun Nov 12, 2017 7:22 pm
Has thanked: 363 times
Been thanked: 1311 times
I bought a gismo for about £30, can't remember what it's called (might be an inverter) it's fine for charging cordless batteries, (just as well cos that's why I bought it), but it only has an output of about 300w, so it would be useless for running 240v tools, but it does solve the age old problem of charging your batteries in the site canteen only to find on your return that they've been swapped for a duff one or maybe just unplugged two minutes after you plugged them in.
PostPosted: Sun Nov 12, 2017 7:37 pm
Has thanked: 38 times
Been thanked: 1182 times
I have to ask, why do you want to change 110 to 230?
Although its easy to say just buy a 110 version of your "xyz" I can appreciate it costs more, but if it has an integral power supply it may be possible to change just that.
PostPosted: Mon Nov 13, 2017 4:57 pm
You can get an auto transformer any size you want, however those many in high quantity are likely cheaper, in the main 120 volt to 230 volt step up auto transformers are used to run UK appliances in the US and since a transformer is heavy and we travel by plane these are normally quite small.
There is a problem with using these with UK site transformers in that the output is 55 - 0 - 175 volt not 230 volt, so OK for Class II equipment but not class I equipment. So we tend to use lumps like this.
Image At £86 not really that expensive considering 3.3 kAV intermittent rating however that is a 30 amp input so you can see why 1.65 continuous that still needs 15 amp input so this is likely the largest step up you can buy off the shelf.
It also will not be RCD protected and the cut out is thermal only so although you could use when there is no electrical engineer on site, I would not allow there use without some sort of protection, except for very special cases.
In fact I don't like the brick step down transformer either, I feel they brake all safety rules and should be banned, they clearly remove and RCD protection, but with a 3 kW brick transformer they will likely supply 54 amp without tripping, i.e. 3000/55 so if there are leads plugged into leads you can get a direct short to earth which will not trip the supply until the insulation melts and wires touch closer to the transformer. The damaged caused by overload often goes undetected, the lead will still pass using a PAT tester but in use the damaged insulation will fail.
So site safety officers are between rock and hard place, rules say 63 volt to earth maximum but yellow bricks are dangerous clearly a fire risk, proper site transformers with MCB's on output are OK it is just the yellow brick, they are likely aware of there being a danger but safety officer may not fully understand where the danger comes from. So anything out of usual and they ban it just to be on the safe side.
So with say a high pressure hot wash you may want to use it both on 110 and 230 volt supply, so either transform up or transform down, since the 230 volt is cheaper transform up seems best option, since it has a transformer already which supplies 30,000 volt for the ignition one can hardly say one in safer than other, as long as the transformer to step up is bolted onto the device so it is considered integral then it brakes no rules.
I know he says
But it really does depend where it is used, as to if you can get away with it. Not talking about danger the 110 volt brick is dangerous to start with, what I am saying is getting away with it.
And your far more likely to get away with a device that looks as though designed for job than something which looks heath robinson.
PostPosted: Mon Nov 13, 2017 8:52 pm
I know he says
Yawn.........yawn!!! Yeah, thanks for that Earwick.. I think :roll:
The Plumbers Anthem
Gas Safe RGI
PostPosted: Mon Nov 13, 2017 8:59 pm
But what's it for?
PostPosted: Mon Nov 13, 2017 10:00 pm
Why not?
Maybe to prove it can be done and get one over the H&S idiots?
PostPosted: Mon Nov 13, 2017 10:18 pm
Still same question, why change 110 to 230.
Yes we know it can be done, but to most it would be a pointless exercise, so to me that suggests that Dickie has some thing else in mind. But .....................what?
PostPosted: Mon Nov 13, 2017 10:21 pm
So you can use your 240 gear on site I’m thinking?
PostPosted: Mon Nov 13, 2017 10:43 pm
But you know as well as I do, you are not allowed to use 240v kit on site, but that's going down the H & S route.
