It is currently Wed May 16, 2012 10:32 pm
PostPosted: Sat Jul 19, 2008 3:02 pm
I've got regular ceramic tiles for the bathroom so they should be fairly easy to cut (well compared to porcelain LOL).
How would you cut the hole for the bog waste pipe?
I do have a core cutter for brick of that size but would that work on tiles? Or do I nibble the hole out?
Actually - It'll probably go across more than one tile so that rules out the core cutter I guess...
Cheers
Nothing you do is a waste of time - especially if it can be used as a bad example by others...
 Post subject:
PostPosted: Sat Jul 19, 2008 5:17 pm
Been thanked: 32 times
I would use a HSS hole saw 100/110mm for the sh*t pipe.
 Post subject:
PostPosted: Sat Jul 19, 2008 8:20 pm
Mark the tile.
Place any glazed wall tile, (glaze down) onto your manual cutter bed, place the marked tile on top. score the curved tile mark by sliding the tile under your scoring wheel (the glazed tile down helps the slide)
Then use a wet cutter to cut lots of little fingers up to your scored mark, then snap the fingers off and neaten up with nippers/sanding stone.
In the event that you have large tiles that require a hole in only one tile, use a hole saw, diamond coated or similar.
 Post subject:
PostPosted: Sun Jul 20, 2008 11:48 am
If you have some spare tiles you could fix them to something and try the core cutter to see if it works. I would guess it would work on ceramic, but not porcelain.
 Post subject:
PostPosted: Sun Jul 20, 2008 5:43 pm
Thanks for all the suggestions :thumbright:
I have way to many tiles so I'll try the core cutter for sure.
But the chances of the whole hole :lol: being on one tile are pretty slim.
If it works I'll let you know
 Post subject:
PostPosted: Sun Jul 20, 2008 9:23 pm
Has thanked: 5 times
Been thanked: 48 times
Wouldnt use the core cutter unless it IS carbide or diamond tipped, if not go for bathstyles option! :wink:
IF IT WERE EASY ITD B BORING!
